Voicemail -- controlling direct-to-voicemil vs. station ring
CallMgr 4.1.3 (soon to upgrade to CUCM 5 or 6), Unity 5.0.1. desired behavior is:
front desk uses 7941 phone to answer all calls. Business rules state use of FWD button to alert employee to receive Xfer. If employee doesn't want to accept call, how can front desk tranfer call directly to voicemail w/o going back through employee phone and the busy/no answer sequence? If I use Unity trunk hunt, and set to go straight to voicemail, then I lose dial-by-extension features for outside callers. So, what I'm looking for is a way to haev outside calls able to use Unity to dial non-DID extensions, while allowing front desk to transfer outside caller from front desk phone to voicemail while bypassing a second ringdown of the employee phone.
Ideas?
Rob Huffman Thu, 01/03/2008 - 05:51
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Joseph,
Here are two good methods to Transfer Directly to VM without ringing the phone a second time;
How to Transfer a Caller Directly into a Cisco Unity Mailbox
http://www.cisco.com/en/US/customer/products/sw/voicesw/ps2237/products_tech_note09186a008015b963.shtml
Or this method;
http://www.cisco.com/en/US/customer/products/sw/voicesw/ps556/products_tech_note09186a00800dea82.shtml
Hope this helps!
Rob
