Cisco Aironet 1130AG access points
Jan 2nd, 2008
We have 2 ways to connect secured and guest access. We cannot get on the internet with guest access but can through the secured access. GDGUEST is missing the default gateway which is why its unable to connect outside. Can anyone please help me figure this out?
ivillegas Tue, 01/08/2008 - 12:35
  • Silver, 250 points or more
Default Gateway is the option to be enabled on DHCP server When you define DHCP pool for clients. You should use the Router's LAN interface address as the Default Router or Default Gateway which is in the same ip subnet as the Guest clients. If you are using 1130 access point as your DHCP server Refer the following URL http://cisco.com/en/US/docs/wireless/access_point/1130/installation/guide/113h_g.html
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
