HSRP not working properly for tunnel interface
Jan 2nd, 2008
Dear all,
When two routers running HSRP that track tunnel interface, configuration as below:
IBSSCC1#sh run int vlan1
Building configuration...
Current configuration : 250 bytes
interface Vlan1
description Connection to Customer LAN
ip address 10.122.222.6 255.255.0.0
ip nat inside
ip virtual-reassembly
ip ospf cost 10
standby 1 ip 10.122.222.2
standby 1 priority 110
standby 1 preempt
standby 1 track Tunnel0
There is OSPF configured between both two spoke routers to hub router.
Today during the outage that, OSPF keep flapping on active HSRP router, however, there is no link flapping can be seen, tunnel interface shows up, but the latency is huge when reach to hub router which cause OSPF unstable, since HSRP is track to tunnel0, so it wont trigger HSRP function take place, may i see some advice how to deal with this situation? is that advisable that add keepalive under the tunnel interface?
Thank you,
s.arunkumar Wed, 01/02/2008 - 21:17
hi,
Try configuring your tunnel 0 interface with "keepalive" command.This wil make the tunnel interface to behave like physical interface and the tunnel0 will go down when the other end tunnel is down...
arun :)
trinawong Thu, 01/03/2008 - 02:25
Thanks Arun!
I tried to add keepalive command 'keepalive 9 5', however, once I finished the command, the OSPF dropped after few seconds, the default keepalive is 10 second, I am not sure what is the value is recommended to put that monitor the tunnel interface and not interrupt the ospf as well.
Please advise. thank you.
s.arunkumar Thu, 01/03/2008 - 03:02
i think the value you configured is ok.
here keepalive packet is send every 9 sec and if it doesnt receive anything within 5 retries then tunnel is set to down.
Do the tunnel is geting down now,or only ospf is droping but tunnel is up??
have you configured on both end of the tunnel ???If not check out that...
guruprasadr Tue, 01/08/2008 - 05:14
HI,
Best values for Keepalive are:
"keepalive 0 3"
>> Try this.
Do RATE if HELPS
Best Regards,
Guru Prasad R
Pavel Bykov Wed, 01/09/2008 - 00:00
What is the latency you are seeing on your tunnel interface? What are your timers for OSPF? If your timers for OSPF are very strict, it can think the link is down while it is not. On the other hand, why do you have such high latency on your tunnel interface?
If you set keepalives to 0 as Guru has suggested, your interface will ALWAYS stay up. You can do this on any interface you want turned on without any cables connected.
