CSS Interface
Jan 2nd, 2008
Is it possible to do bundling of the ethernet interfaces on the CSS... I mean something similar to etherchannel...
Any inputs.. ??
Overall Rating: 4 (1 ratings)
Gilles Dufour Thu, 01/03/2008 - 01:24
not possible at layer 2.
But if you need more bandwidth on inbound, you can create separate L3 vlan, assigned them to a single interface and create on the gateway static routes pointing to each vlan.
If your gateway is a cisco router, it should be able to loadbalance over the static routes per packet or per session.
Gilles.
