LAN Lite on 2960 ok for CCNA study?
Jan 2nd, 2008
I'm building a CCNA home lab. I'm just kinda jumping in and learning, so when I ordered 2 new 2960s I didn't realize they came with something new called LAN Lite. I'm thinking of returning them and getting some with LAN Base. (I think)
Anybody got any info about LAN Lite on a 2960 and studying for the CCNA? Is it fully functional enough?
Thanks...
Hi There
I have to admit I have never heard of LAN Lite. When I was setting up my own lab I purchased all my equipment 2nd hand from Ebay and would look for equipment with the IOS version I wanted.
You might consider posting your question on the LAN Switching and Routing forum. I think you will like get a quick response there.
Best Regards & Best Wishes for 2008 and beyond,
Michael
bs_texas_ Sun, 01/13/2008 - 01:22
Thanks for the reply. I posted over there as well, in another LAN Lite thread, but haven't seen a reply.
Does anybody else have any info on LAN Lite on a 2960 with regards to studying for the CCNA?
Bennie
bs_texas_ Mon, 01/14/2008 - 14:42
Thanks for your reply and the link.
In the list of links on the left on that page, the last item is "Unsupported Commands in Cisco IOS Release 12.2(37)EY".
http://www.cisco.com/en/US/docs/switches/lan/catalyst2960/software/release/12.2_37_ey/configuration/guide/swuncli.html
It looks like there are a lot of unsupported commands with this version. For instance, "show mac-address table". Or, "show running-config vlan".
It seems to me (a novice) that those are commands that would be needed while studying for the CCNA.
Other comments welcome. I need to decide today or tomorrow if I need to send the 2 2960's back and get the more robust version.
Thanks...
