%STANDBY-3-DUPADDR: Duplicate address
Jan 2nd, 2008
I am getting continuos error on my core switches where i am running hsrp.... the MAC reporting as Duplicate is the Virtual MAC of HSRP. I have read the Documentation where cisco is talking about STP & Mulfunctioning of the switch. I have tested for the STP loops but i did not find any. How i could check whether my switch is proper or malfunctioning, as i dont see any problem, the core switches are 4507R. find below the error message.
Vlan8, sourced by 000d.2822.f57f
.Jan 3 01:22:17.834 SA: %STANDBY-3-DUPADDR: Duplicate address 132.1.1.251 on Vl
an1, sourced by 0000.0c07.ac00
.Jan 3 01:50:43.226 SA: %STANDBY-3-DUPADDR: Duplicate address 10.0.160.2 on Vla
n11, sourced by 0000.0c07.ac00
.Jan 3 01:51:40.778 SA: %STANDBY-3-DUPADDR: Duplicate address 10.0.80.2 on Vlan
6, sourced by 0000.0c07.ac00
.Jan 3 02:00:43.142 SA: %STANDBY-3-DUPADDR: Duplicate address 10.0.48.2 on Vlan
4, sourced by 0000.0c07.ac00
.Jan 3 02:02:54.930 SA: %STANDBY-3-DUPADDR: Duplicate address 10.40.1.2 on Vlan
40, sourced by 0000.0c07.ac00
.Jan 3 02:05:59.782 SA: %STANDBY-3-DUPADDR: Duplicate address 10.1.32.2 on Vlan
22, sourced by 0000.0c07.ac00
.Jan 3 02:44:14.190 SA: %STANDBY-3-DUPADDR: Duplicate address 10.0.16.2 on Vlan
.Jan 3 02:57:19.330 SA: %STANDBY-3-DUPADDR: Duplicate address 10.40.1.2 on Vlan
.Jan 3 03:25:30.578 SA: %STANDBY-3-DUPADDR: Duplicate address 10.0.112.2 on Vla
.Jan 3 03:34:35.917 SA: %STANDBY-3-DUPADDR: Duplicate address 10.1.16.2 on Vlan
21, sourced by 0000.0c07.ac00
.Jan 3 03:37:49.661 SA: %STANDBY-3-DUPADDR: Duplicate address 132.1.1.251 on Vl
Danilo Dy Fri, 01/04/2008 - 11:28
  • Blue, 1500 points or more
The error message not necessary HSRP problem. Since the error received by the HSRP VIP MAC Address, this suggest a router or switch configuration problem that may cause the one or more of the following;
1. Momentary STP Loop
- make sure you follow recommended configuration to prevent/avoid STP Loop. i.e. assign primary and secondary root bridge
2. Etherchannel misconfiguration problem
- check the config and logs
3. Both routers in HSRP group is in Active state
- check both routers HSRP status and interface status whether its flapping. i.e. show standby, show ip int brief
Dandy
