okuehn Thu, 01/03/2008 - 23:02
  • Bronze, 100 points or more
here are the installation instructions:
Installation instructions:
1) You must be logged on as "root" at the MPE CLI (Command Line Interface).
2) Copy this file onto your MPE system. (A good location is generally /partB).
3) From the CLI, navigate to the directory where you saved the language pack file.
4) Execute the language pack file. For example, for United Kingdom English:
"sh ./CUMPE_LanguagePack_en_GB-2.0.2.126.bin"
5) The installer displays the licensing agreement. After reading the licensing agreement,
press Enter to select "I accept the terms of the License Agreement" and click "Install".
6) Repeat steps 2 to 5 for all language packs.
7) Log in to Cisco Unified MeetingPlace Express using the web and click "Administration".
8) Go to "System Configuration" > "Usage Configuration".
9) Click the arrow next to the "Language 1" field to see the languages available on the system.
Select the language or languages you would like to use. If you have the "languages" license,
you can configure up to 4 languages active at the same time. Otherwise, you will be able
to configure only one. Also, the first language selected will be the initial lanugage
users are greeted in until they enter their profile number.
10) After all language packs are installed and the desired languages are activated, restart
the system from the CLI as follows:
"mpx_sys restart".
11) Once the system restarts, MeetingPlace Express will start automatically. Verify you can schedule and attend meetings in the languages/locales you have activated.
you can find additional information in the release notes:
http://www.cisco.com/en/US/partner/docs/voice_ip_comm/meetingplace_express/2_0/english/release/notes/b_rn20.html#wp265343
cheers, Oliver
