QOS problems with Cellular int and IPSec tunnels
Jan 3rd, 2008
Guys,
I have deployed an 1841 with a Cellular interface. I have 2 IPsec tunnels from the router to my data centers. The important traffic from the remote site is telnet.
I am seeing alot of drops on the cellular interface at the moment.
Could anyone suggest a QOS strategy to eliminate the performance problems and drops I am seeing ?
Thanks !
site#show queueing int cellular 0/0/0
Interface Cellular0/0/0 queueing strategy: fair
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 6388
Queueing strategy: weighted fair
Output queue: 0/1000/64/6388 (size/max total/threshold/drops)
Conversations 0/10/16 (active/max active/max total)
Reserved Conversations 0/0 (allocated/max allocated)
Available Bandwidth 1350 kilobits/sec
site#show int cellular 0/0/0
Cellular0/0/0 is up, line protocol is up
Hardware is EVDO Rev A/Rel 0/1xRTT-800/1900MHz / SP
Internet address is X.X.X.X/32
MTU 1500 bytes, BW 1800 Kbit, DLY 100000 usec,
reliability 255/255, txload 13/255, rxload 1/255
Encapsulation PPP, LCP Open
Open: IPCP, loopback not set
Keepalive not supported
Time to interface disconnect: idle 00:02:00
Last input 00:00:00, output 00:00:00, output hang never
Last clearing of "show interface" counters 18:40:57
Output queue: 1/1000/64/6388 (size/max total/threshold/drops)
Conversations 1/10/16 (active/max active/max total)
5 minute input rate 0 bits/sec, 1 packets/sec
5 minute output rate 93000 bits/sec, 31 packets/sec
89354 packets input, 8368739 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
1169272 packets output, 432852070 bytes, 0 underruns
0 output errors, 0 collisions, 1 interface resets
0 carrier transitions
DCD=up DSR=up DTR=up RTS=up CTS=up
