QoS on PPPoE setup.
Jan 3rd, 2008
I'm trying to setup a QoS policy on my ADSL connection. I have a separate dsl modem in bridging mode (no cisco) and a 2800 router.
What I'm not sure about is if I should attach the service-policy to the Dialer interface of the actual physical Gi0/1 interface?
Most of the documents talk about ATM interfaces and they put the service-policy on the pvc, but I'm not able to find anything on the Ethernet.
Any suggestions?
Thank you,
Overall Rating: 4 (1 ratings)
paolo bevilacqua Thu, 01/03/2008 - 11:24
  • Hall of Fame,
    Founding Member
best would be for you to aquire an HWIC-1ADSL or WIC-1ADSL to connected directly the ADSL circuit and be guaranteed that everything works nicely.
However, if you cannot do that, here is a configuration example for a nested policy-map that first shapes and then applies priority:
http://www.cisco.com/en/US/tech/tk543/tk545/technologies_tech_note09186a00800b2d29.shtml
