TACACS server - password recovery
simonvyrdal
I don't know the username/password of the TACACS server.
Is it possible to recover the username/password and how do I do this ??
Simon
5 Replies 5
akemp
Level 5
Level 5
Is it an appliance or server ?
If its the server version you can log into the console (either physical or terminal services), pull up a browser, and see if you can log in via http://127.0.0.1:2002 . If the server session policy has the "allow automatic local login" checked you will be logged in via the loopback without a password.
I will try it as soon as I can. Then I will be back. Thanks.
Sorry for a question , If after i done the password recovery . The config for the Tacas and tech-support log will be lost ?
David Stanford
Which version of software is running on your TACACS server? ACS X??
I will be back as soon as I know. Thanks.
