Client can't connect to VPN
Jan 3rd, 2008
I'm trying to connect a VPN client to a VPN, when connecting form home I have no problems, but when I try from work I have the Message Reason 412: The remote peer is not longer responding. @ work I'm behind a Pix 515E, but the VPN I'm trying to connect to is in another location.
I'm wondering if the pix is blocking the client???
acomiskey Thu, 01/03/2008 - 11:08
  • Green, 3000 points or more
It is very likely the local pix at work is blocking your vpn outbound. ESP, udp 500, udp 4500 would need to be allowed outbound.
bill_olah Thu, 01/03/2008 - 17:40
Do you have a static NAT translation behind your PIX or are you using the global PAT?
If you are using the global PAT, try it with a static NAT
