Security Device Manager
Answered Question
Jan 3rd, 2008
I am trying to get the SDM working on my Windows XP machine running IE 7. Everytime I launch the SDM and put in the IP address of the router it always comes up with with this box and it does not work( See attachement)
Correct Answer by cpubob about 9 years 1 month ago
Do you have java installed on your computer?
Do you have java enabled in your broswer?
Overall Rating: 5 (1 ratings)
Correct Answer
cpubob Thu, 01/03/2008 - 11:54
brian-utter Thu, 01/03/2008 - 12:01
I do have java 6 update 3 installed. In IE 7 under Tools -> Internet Options -> Advanced in the Java (Sun) Section there is a check mark in the box next to "Use JRE 1.6.0_03 for (requires restart)
brian-utter Thu, 01/03/2008 - 12:14
I found the solution. In IE7 on the advanced tab I had to put a check in allow active content to run files on my computer. Thanks for helping.
Brian
