h323-gateway voip bind srcaddr
Jan 3rd, 2008
I am working on voip setup. I need to know about the command h323-gateway voip bind srcaddr. In which scenario this command is used? Actually i have an ospf core network. Each router is accessible from other router through multiple links. Regarding this command i think, if i create a loopback interface on all routers and this interface would be the source of voice packet and destination would be the loopback of the target router then my voice call will never drop if any link down the network. Because loopback would be accessible from everywhere.
Need your responses
Best Regards
Brandon Buffin Thu, 01/03/2008 - 12:47
This command is used on an H.323 gateway when you want to specify the source address for H.323 packets. Yes, you can certainly create a loopback address and source H.323 packets from this interface. This would help with the resiliency of your network as you describe.
Hope this helps. If so, please rate the post.
