Site-to-site VPN Tunnel not rebuilding after internet loss on either end
Jan 3rd, 2008
I have two sites which are connected by a site-to-site VPN tunnel.
If either site loses their internet connection (for any reason), the connection doesn't automatically rebuild. The only way I have found to fix the issue is to 'clear crypto session" on the head end.
Anyone have any clue what could be causing this? Pretty standard configuration I thought..
Danilo Dy Fri, 01/04/2008 - 11:41
What did you see in the log?
You may need to update the IOS. In Router S2S VPN, there is a bug when connection is terminated abruptly - may be present to PIX/ASA as well.
I have similar problem and was fixed by IOS update.
tylerlucas Fri, 01/04/2008 - 12:45
Which logs should I be looking at when this occurs? I'm fairly new to VPNs.
I could recreate the issue after hours and take a peek.
tylerlucas Fri, 01/04/2008 - 12:47
For the record, the head end is on a 2821, and the other end is on an 877.
Danilo Dy Sat, 01/05/2008 - 10:18
Can you post the "show ver" output of both routers?
I can't remember the exact text in the log but it's with "SPI". Cisco solution is to clear the sa.
