Cisco 2610 ADSL
scott.k.logan
I have a cisco 2610 with a WIC1-ADSL card, and the c2600-is4-mz version of IOS installed...
...My problem, I do believe, is in configuration. If I show interface adsl 0/0, it shows that there are packets being sent and received. On the BVI1 interface, they're only being outputted. I'm using Embarq (sprint) DSL, and they told me to use 8/35 for my vpi and vci...I have a static IP. What am I doing wrong? I can't ping the gateway from my router...?
--scott
21 Replies 21
paolo bevilacqua
please try:
interface ATM0/0
no bundle-enable
no bridge-group 1
no pvc 8/35
interface ATM0/0.1 point-to-point
bridge-group 1
pvc 8/35
encapsulation aal5snap
chschroe
I am not sure I understand why you need a BVI to accomplish your goal here.... you don't have any other interfaces in the bridge group to receive L2 packets.
Nothing is actually being bridged here, so you could probably just throw the ip configuration and the nat on the subint and get going!
NS
Hi NS,
Well, I'm nor sure about Embarq (sprint) DSL, but many ISPs use bridged rfc1483 encapsulation for their service, so that is the reason for the BVI and the suggest configuration.
The reason why they to that, is because when the CPE is a "dumb" modem/bridge, a PC directly connected via ethernet will work with either rfc1483 bridged or PPPoE encapsulation, but it would not work with rfc1483 routed encap.
I configured my old dsl 'modem' to use rfc1483...but I thought that was covered when I set the encapsulation to aal5snap in the pvc 8/35 within the atm 0/0...
Does it work with the config changes I suggested ?
The thing is that you have to use point-to-point interfaces for rfc1483, and the main ATM it is point-to-multipoint instead. So the need for a subinterface.
I did give that a try, simply executing those commands on top of the posted config...I would like to try it with a clean config, though. Now, I got the drift that you left the bvi in place and bridged it to the atm0/0.1, yes?
--scott
Yes. Pasting the lines should have been enough. May be they have routed encap, as NS incidentally suggested.
To try that, remove bridging, and configure IP directly under atm0/0.1
I'll try that with a fresh configuration right now. I did find, on google, someone configuring one of sprint's (who is now embarq) dsl modems as follows. It mentions encap;
DHCP= Server
Client IP Pool Starting Address= 192.168.1.2
Size of Client IP Pool= 1
Primary DNS Server= (supplied by Sprint) (204.x.x.10)
Secondary DNS Server= (supplied by Sprint) (199.x.x.10)
Remote DHCP Server= N/A
TCP/IP Setup:
IP Address= 192.168.1.1
IP Subnet Mask= 255.255.255.252
RIP Direction= Both
Version= RIP-1
Multicast= None
IP Policies=
Edit IP Alias= No
ISP's Name= MyISP
Encapsulation= ENET ENCAP
Multiplexing= LLC-based
VPI #= 8 (Assigned by Sprint)
VCI #= 35 (Assigned by Sprint)
Service Name= N/A
My Login= N/A
My Password= N/A
Single User Account= Yes
IP Address Assignment= Static
IP Address= (assigned by Sprint)
ENET ENCAP Gateway= (assigned by Sprint)
alright, I tried a fresh configuration, and I attached it. I still can't ping my next hop, but both the atm interfaces are transferring packets. Here are the show interfaces:
CNRouter#show interfaces ATM 0/0
ATM0/0 is up, line protocol is up
Hardware is DSLSAR (with Alcatel ADSL Module)
MTU 4470 bytes, sub MTU 4470, BW 448 Kbit, DLY 4570 usec,
reliability 210/255, txload 1/255, rxload 1/255
Encapsulation ATM, loopback not set
Encapsulation(s): AAL5 AAL2, PVC mode
23 maximum active VCs, 256 VCs per VP, 1 current VCCs
VC Auto Creation Disabled.
VC idle disconnect time: 300 seconds
Last input 00:00:00, output 00:00:47, output hang never
Queueing strategy: Per VC Queueing
5 minute input rate 1000 bits/sec, 2 packets/sec
1607 packets input, 188486 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
0 input errors, 994 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
7 packets output, 596 bytes, 0 underruns
0 output errors, 0 collisions, 2 interface resets
CNRouter#show interfaces ATM 0/0.1
ATM0/0.1 is up, line protocol is up
Internet address is 65.41.113.117/24
MTU 4470 bytes, BW 448 Kbit, DLY 4570 usec,
reliability 216/255, txload 1/255, rxload 1/255
Encapsulation ATM
1734 packets input, 201766 bytes
0 OAM cells input, 0 OAM cells output
AAL5 CRC errors : 0
AAL5 SAR Timeouts : 0
AAL5 Oversized SDUs : 0
Here is the running-config:
version 12.3
hostname CNRouter
boot-start-marker
boot-end-marker
no aaa new-model
ip subnet-zero
ip cef
ip name-server 65.41.112.28
ip dhcp excluded-address 192.168.1.0 192.168.1.99
ip dhcp pool cnpool
network 192.168.1.0 255.255.255.0
default-router 192.168.1.1
dns-server 65.41.112.28
netbios-name-server 192.168.1.6
interface ATM0/0
no ip address
no atm ilmi-keepalive
dsl operating-mode auto
ip address 65.41.113.117 255.255.255.0
pvc 8/35
interface Ethernet0/0
ip address 192.168.1.99 255.255.255.0
ip nat inside
full-duplex
interface Serial0/1
no ip address
shutdown
no ip http server
ip classless
ip route 0.0.0.0 0.0.0.0 65.41.113.1
line con 0
line aux 0
line vty 0 4
login local
end
Make sure you're pinging from the ATM interface... you don't have enough configuration for your nat to work at this point. :-)
NS
I put ip nat outside on the ATM0/0.1 interface, now what else do I have to do to configure nat?
Hi, by the example posted seems like it should be bridged, however you have many errors also:
would try another router to verify that the circuit is working first.
When you say another router, do you mean try the WIC in a different router? or try a different DSL line? or try a different WIC?
--scott
Would try a "consumer level" dsl router on the same line.
