Clarification on QOS
I am currently self studying for QOS 642-642 exam. Since the book that I use didn't state this clearly, I need clarification regarding this matter.
When I use CBWFQ with either bandwith or priority command, will the layer 2 header be included in the calculation?
2nd, since the max-reserve-bandwith always defaults to 75%, will the class-default always get at least a minimum of 25% bandwith of the link (assuming that I didn't change the default setting)? Thanks.
Overall Rating: 5 (1 ratings)
Brandon Buffin Fri, 01/04/2008 - 06:14
When using the bandwidth or priority commands, every bit passing through the interface is included in the calculation. This would include headers.
The bandwidth command sets a minimum amount of bandwidth for a class, but not a maximum. The priority command sets a minimum and maximum. So, at a given point in time, a class using the bandwidth command could be using more than 75% of the link. You just cannot reserve more than 75% of the link without changing the max-reserve-bandwidth. When extra bandwidth is available above what is reserved, it can be used by class class-default. If class-default does not need the bandwidth, it is divided among the other configured classes proportional to their configured rates.
Take a look at the following link.
Hope this helps. If so, please rate the post.
