Cas-Custom and Trunk-Group commands
Jan 3rd, 2008
Hey all,
My situation is this:
1 Existing T1 between Nortel and 2821 with the following config:
controller T1 0/0/0
framing esf
linecode b8zs
ds0-group 0 timeslots 1-24 type e&m-wink-start
cas-custom 0
trunk-group PBX timeslots 1-24
description PBX Connection
This is a working T1. My client wants to add a second T1 and describes the Nortel set-up like this:
The PBX is now setup as 48 channels, not 24. So..even though we have 2 separate T1's (loop4 and loop5) they are all stuck in 1 route and each assigned a channel 1-48.
We added a second T1 with the following commands:
controller T1 0/1/0
framing esf
linecode b8zs
ds0-group 1 timeslots 1-24 type e&m-wink-start
cas-custom 1
The calls started to fail after the 1st call. Our window closed before we could do some real troubleshooting on this part of the config so I have to get another window to make changes but I wanted some feedback since I have not used the "cas-custom" command with the "trunk-group" subcommand.
Does anyone have experience with this?
thanks
Try creating a trunk group and add the max-calls 48 to it and change your hunt scheme accordingly.
Example:
trunk group PBX
max-calls voice 48
hunt-scheme sequential
controller T1 1/0
framing esf
linecode b8zs
cas-custom 0
trunk-group PBX
Apply this trunk group to your pots dial peer
dial-peer voice XX pots
trunkgroup PBX
