trace mac-address
Jan 3rd, 2008
Hi all,
By using mac-address we can trace the IP address of the particular switch port, like that is there any way to trace mac-address & connected switch port with IP address.
It would be appreciated.
Naidu.
Overall Rating: 4 (1 ratings)
Jon Marshall Thu, 01/03/2008 - 23:49
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Naidu
If you have just an IP address you need to go onto the device that has the layer 3 interface for the subnet of that ip address and look at the arp table eg.
PC = 192.168.5.10 vlan10
Lgo onto the switch with the vlan 10 L3 interface on it and run
"sh arp | include 192.168.5.10"
This will give you the mac-address of the PC. You can then run
sh mac-address-table address "xxxx.xxxx.xxxx" (IOS)
or
sh cam xx-xx-xx-xx-xx-xx (Catos)
Note that the above command(s) may well return a port that is connected to anothe switch (most likely a trunk). You would then need to log onto the switch at the other end of the link and run the mac-address commands again.
Jon
ilnaiduccna Fri, 01/04/2008 - 02:07
Hi Jon,
Thanks for your early reply.
I tried both commands and worked out.
Naidu.
