CSM Support on C7613 with SUP720
Jan 4th, 2008
Hi !
I tried to use the CSM Modul in a C7613(SUP720) (unsupported module)- unfortunately I have to use the SRB Images as I am also using SIP/ATM Modules.
Do you know - or can you provide me with some info - if ths CSM Modul is supported on a C7613.
Is there any Matrix available which Image supports which kind of hardware ??
In Feature Navigator I can not select hardware as an option.
chschroe Sat, 01/05/2008 - 13:19
The CSM is officially dead in the 12.2(SR) train. There will be no further support for that module in that platform.
Your migration path is the Application Control Engine in the 7600 series.
