CLI equivalent commands for Smartport Roles
maltuna Fri, 02/22/2008 - 14:07
You may try the following:
http://10.10.10.10/exec
Use this where 10.10.10.10 is the ip of your catalyst express switch. This sort of allows you to issue cli-like commands to the switch, and allows you to see what the configuration is. I'm not sure if this will help or not. What you can actually do here is also very very limited.
