mulithomed internet BGP question
Jan 4th, 2008
I have two DS3 connections with two diffrent Service providers. Each with thier own CPE router. Now I want traffice to flow equally accross both routers so I will for not just adversite with no prepending. My Question is the return traffic. If client makes a connection from the internet and is routed though Service provider 1 and then hits the firewall how does the firewall know which conntection to send the return traffic?
Overall Rating: 5 (2 ratings)
royalblues Fri, 01/04/2008 - 06:09
The firewall will route the traffic based on its routing table for the source which could be via SP2.
On the internet its possible that a packet gets routed asymmetrically
Narayan
Danilo Dy Fri, 01/04/2008 - 06:14
The firewall will always use the configured default gateway. The default gateway could be your first router or second router - depends on how you configure it (i.e. HSRP and which one is active).
Then the router will make decision by using the following BGP routing algorithm in this link http://www.cisco.com/warp/public/459/25.shtml
Dandy
