Calls From IP Phones through particular FXO ports
Jan 4th, 2008
I have two 4 port FXO cards and I have already configured separate IP Phones to make outbound calls through separate FXO ports. But I cannot configure more than one IP Phone to make outbound calls through a partcular FXO port. E.g I want IP Phones with ext. 1023 and 1001 to make outbound calls only through FXO port 3/2 only. I also want only one IP Phone to be able to make calls through several ports. E.g. I want IP Phone with ext. 1016 to be able to make outbound calls throught FXO ports 2/0, 2/1, 2/2, and 2/3 only. Attached is my "sh run" config. pls help
paolo bevilacqua Fri, 01/04/2008 - 09:18
  • Hall of Fame,
    Founding Member
use trunkunk group for this:
voice-port x/y
trunk-group pots
dial-peer voice 101 pots
destination-pattern 9T
trunkgroup pots
You can also have mutliple trunkgroup under one DP, and select different preferences and hunt schemes for ports comprising the trunk group.
douhanm Fri, 01/04/2008 - 13:16
I am not convinced this solves his problem 100% because he also wants to limit specific phones so they can only use specific dial-peers, this needs COR or partitions in addition to the trunk config
peternnaji Mon, 01/07/2008 - 04:21
I have tried the trunk config and it still does not sovle my problem. Please what necessary configs do I need for the COR or partitions.
paolo bevilacqua Mon, 01/07/2008 - 04:41
  • Hall of Fame,
    Founding Member
As suggested above, trunk-group only groups multiplke lines under a single DP.
Then, are you willing to do a translation rule on CCM for a certain partition, so there is not need to use "answer-address" and prefix on the router ?
Or do you prefer that all the config is in the GW ?
peternnaji Mon, 01/07/2008 - 04:56
Presently I have more of my configs done on the router, I would prefer if the config is done on the router, but would also like to know the implications of having them on the CCM.
Thank you.
