ip helper address
anitachoi3
I config the router with 5 vlan, the DHCP server is on vlan 1 (default vlan).
The DHCP server is MS 2000 server. I cannot get the ip address from vlan 2, 3, 4 and 5. If I put the client pc on vlan 1, I can get the ip address (172.16.1.0/24). anything I missing? It is related to IOS?
R1
interface FastEthernet0
no ip address
interface FastEthernet0.1
description Vlan 1
encapsulation dot1Q 1 native
ip address 172.16.1.10 255.255.255.0
ip helper-address 172.16.1.3
interface FastEthernet0.2
description Vlan 2
encapsulation dot1Q 2
ip address 172.16.2.10 255.255.255.0
interface FastEthernet0.3
description Vlan 3
encapsulation dot1Q 3
ip address 172.16.3.10 255.255.255.0
interface FastEthernet0.4
description Vlan 4
encapsulation dot1Q 4
ip address 172.16.4.10 255.255.255.0
interface FastEthernet0.5
description Vlan 5
encapsulation dot1Q 5
ip address 172.16.5.10 255.255.255.0
Danilo Dy
Router config looks okay. Please post switch config. Also, try this including this command line in Fa0.2 to Fa0.5 "ip forward-protocol udp".
Make sure that DHCP server;
- Have a scope for 5 VLANs and activated
- Authorized.
- See http://www.windowsnetworking.com/articles_tutorials/w2kdhcpc.html
Following are DHCP Troubleshooting Links:
Client side http://technet2.microsoft.com/windowsserver/en/library/1cba3948-5605-4a19-89ef-8762cdcdc7ad1033.mspx?mfr=true
Server side http://technet2.microsoft.com/windowsserver/en/library/6350df25-a5d9-46e4-82c7-85d9141aa24f1033.mspx?mfr=true
Network side http://www.cisco.com/en/US/tech/tk648/tk361/technologies_tech_note09186a00800f0804.shtml
Dandy
Edison Ortiz
I'm assuming you've configured scopes in the DHCP server for each Vlan. What options did you enter under the scope ? One of the options must be the 'router' option (DHCP Option 003) which should be represented by the IP address of each Vlan.
For instance, for Vlan 5, the router option should be 172.16.5.10 under DHCP scope at the server.
BTW, you don't need an ip helper command under Vlan 1.
In addition to Edison remarks, also check trunk on swithc side ensuring those vlans are indeed passed as well as corresponding vlan membership in switchports.
Jorge Rodriguez
tyagi.vineet
Router Config is ok. could you please post switch running-config ?
Danilo Dy
- Authorized.
Dandy
