IPSEC connection using Multiple Context
Jan 4th, 2008
I read that when you enable multiple contexts that it disables VPN services such as IPSEC is this true? I have a client that has two ASA across a WAN and they want to secure the traffic and extend over to either side the different VLANs.
ccie3483 Fri, 01/04/2008 - 08:10
sounds good..so what would you suggest if the following.
I am trying to extend the different vlans across
in a secure fashion. could i just simply trunk
the two on either side and use an IPSEC tunnel in the middle? But then i will not be able to keep the traffic separate for each vlan? any suggestions?
