NAT help
Jan 4th, 2008
I really don't know much about NAT and I have a problem.....
I need to translate my local subnet 172.22.0.0/16 to 172.25.0.0/16 when going across one VPN tunnel, I therefore also need to translate incoming traffic back from 172.25.0.0/16 to 172.22.0.0/16. As some of these hosts are servers, I need them to keep their same last octect addresses when translated.
I've attached my config. I'd like to know whether this will do the job...it makes logical sense to me but looking at examples I'm not sure whether I have the pools right.
So, just to clarify,
172.22.0.0 - my local network
172.25.0.0 - the network that I want to translate to
10.2.0.0 - the only network that I want this translation to apply to.
Any help would be much appreciated!
Thank you,
J
jigsaw2026 Fri, 01/04/2008 - 07:50
Actually, on second thoughts, I think I can get away with the following:
ip nat inside source static network 172.22.0.0 172.25.0.0 /16 route-map CHOW
route-map CHOW
match ip address 115
access-list 115 permit ip 172.22.0.0 0.0.255.255 10.2.0.0 0.0.255.255
ip nat outside source static network 172.25.0.0 172.22.0.0 /16
Any thoughts appreciated!!!
J
