ankbhasi Fri, 01/04/2008 - 07:36
  • Cisco Employee,
Hi Friend,
Can you please update the router platform you are having and the release which that router is running?
Ankur
Charlie Mayes Fri, 01/04/2008 - 07:42
Right now I am performing this function on a Cisco simulator and have not yet tried the command on my Cisco 2620's. May be that is the issue. I just read in a Cisco Book that all Cisco Routers come with the DHCP function by default and you can enable it or not on any router. So was just wondering if it was not working because I am using a simulator instead of a traditional router. The service DHCP command is not available in my simulator.
ankbhasi Fri, 01/04/2008 - 07:52
  • Cisco Employee,
Hi Friend,
That could be an issue. This command was first introduced in 12.0(1)T release and even small router platforms also support DHCP server confguration.
Ankur
Charlie Mayes Fri, 01/04/2008 - 08:11
Thanks for your help. I will try it on m router rather than my simulator and see what happens. Thanks again.
