Bridging calls received on two different lines (7941G)
Jan 4th, 2008
Hello Experts,
I am trying to use the join or conference softkey to bridge two received calls on two different lines on a 7941 IP Phones. The situation is that the receptionist receives an incoming call on Line 1 and the second incoming call on line 2. She needs to join/bridge these two calls but this is not working with Cisco IP Phones. I saw many posts with the same issue on this forum but none of the answers resolves the problem. I invite you to creat the situation that I just mentionned, you will notice that it's not working. Please note this is a basic fonctionality and it works with Avaya phone system by default without any extra configuration. My client has invested big $$$$$ on Cisco IP Telephony and I need your help to make this work. We are using CCM 5.1
MK
Overall Rating: 4 (1 ratings)
Rob Huffman Fri, 01/04/2008 - 11:15
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi MK,
Hope all is well with you! The Feature that you are looking for is called "Join Across Lines". Sadly this is not available until CCM 6.1
Cisco Unified Communications Manager 6.1 introduces two new features that help increase collaboration and improve access to coworkers. The first one is the Join Across Lines feature for connecting multiple calls or conferences and the second is a Single Button Barge feature that allows authorized users to enter a call as an additional party by pressing a single key.
Join Across Lines
When the Join Across Lines feature is enabled, users can join calls across different lines that appear on their phone. The feature enables the executive staff and other users to swiftly connect different parties into a conversation.
A further refinement of this feature is a "join-pending" mode. This mode is invoked through a softkey when there is only one joinable call in progress. In join-pending mode, the primary user is prompted to join more calls and may complete the joining process as additional calls come in or are dialed out.
With the Join Across Lines feature, conference chaining is also possible. When two or more calls are already in a conference, users can chain together conference calls that appear on their phones.
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_data_sheet0900aecd806e86dd.html
Join Across Lines
(SCCP phones only)
Allows users to apply the Join feature to calls that are on multiple phone lines.
http://www.cisco.com/en/US/docs/voice_ip_comm/cuipph/7961g_7961g-ge_7941g_7941g-ge/6_1/english/administration/guide/7961usr.html#wpmkr1056426
Hope this helps! Sorry man!
Rob
mightyking Fri, 01/04/2008 - 11:22
Thanks for the reply Rob!!!!
I am at 5.1, my next upgrad would be 6.0(1) and then 6.1. Am I right?
MK
