Localize 7921g
Jan 4th, 2008
it is possiblibe to change the language on 7921g, if affermative how? Where I found the files and the procedure?
I search in cisco web site but I'm not find anything.
I have a CME on 2811.
Thank you
Augusto.
Paolo Bevilacqua Fri, 01/04/2008 - 11:13
Hi Augusto,
can you take a "debug tftp events" when you reset the phone ? Perhaps cisco has "forgot" to release the files for CME so they have to be extracted from the CM files.
Paolo Bevilacqua Sun, 01/06/2008 - 03:41
Yes, because ot that I said that cisco "forgot", after one year and more from introduction, to make locales avaialble for the 7921 on CCME.
In practice, once you have the files, taken from CCM as necessary, it should work fine.
tlippolis Tue, 02/16/2010 - 22:28
Use this file CME-locale-it_IT-7.0.1.1.tar  localization ok for 7921g
