Ether-channel link utilization question
Jan 4th, 2008
I have a 3Gb layer-2 ether-channel between (2) 6509s running IOS. It currently runs at about 2.5Gb during peak hours.
What I've noticed though is that utilization on the individual links is not equal. 2 run at about 95% while the third runs at 80% during peak. I am in the process of adding additional links but am wondering why this would occur.
No load-balancing for the channel has been configured, so here is what it is defaulted to:
EtherChannel Load-Balancing Configuration:
src-dst-ip
mpls label-ip
EtherChannel Load-Balancing Addresses Used Per-Protocol:
Non-IP: Source XOR Destination MAC address
IPv4: Source XOR Destination IP address
IPv6: Source XOR Destination IP address
Any feedback would be appreciated.
massimiliano.se... Fri, 01/04/2008 - 10:51
  • Silver, 250 points or more
I think that the method of load balancing depends on your traffic type.
Look at:
Understanding load balancing and Configuring EtherChannel Load Balancing
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.2SXF/native/configuration/guide/channel.html#wp1020414
And Understanding EtherChannel Load Balancing and Redundancy on Catalyst Switches
http://www.cisco.com/en/US/tech/tk389/tk213/technologies_tech_note09186a0080094714.shtml
I hope this helps.
Best regards.
Massimiliano.
Edison Ortiz Fri, 01/04/2008 - 10:51
  • Hall of Fame,
    Founding Member
What you are seeing is normal. It's very hard to get a 'true' load-balancing amongst all links. It's not a per-packet load-balancing.
A src-dst flow may hash via one link for 'conversation A' and hash via another link for 'conversation B'. 'Conversation A' may require more bandwidth and will show on the % utilization on the interface.
Please check out this article:
http://www.cisco.com/warp/public/473/4.html
johgill Sat, 01/05/2008 - 09:05
  • Bronze, 100 points or more
Good points here. It's a tradeoff for quick hardware hashing, you will never get perfect load balancing.
You can, however, change the etherchannel load balance criteria. Depending on what type of traffic this is, you will see better results with different inputs.
For instance, load-sharing on MAC addresses when you have an L2 etherchannel between 2 routers, you will get poor balancing since there are only 2 mac addresses in that network. If your traffic has multiple flows per IP address, you will likely get better results by using src-dst IP and L4 ports:
"port-channel load-balance src-dst-port"
12.2(33)SXH also has some enhancements in this area.
If you are curious to calculate which link a given flow should be taking, you can use:
"rem login sw"
then
"test etherchannel load-balance interface
address pair>"
