call not going to pstn
kolawole1
i have a callmanager infrastructure i am able to call local phones but i can not call pstn i m using mgcp as signaling protocol what is going wrong ?
Attached here is my gateway config
Rajesh Revuru
Level 4
Level 4
Hello:
1. Can you give us more details about type of connection you have for PSTN( Ex: FXO,PRI/BRI)
2. How is route pattern is configured.
3. What happens when you dial a PSTN number ( Fast busy or Any recorded announcements) ?
I have an fxo connection to pstn
I create 3 route pattern and assign each to a partition and then add partition to css
If i dialed pstn number i hear regular tones and some beeps
i was able to call other local ip phones
The router is connected to a pbx through the fxo port
