RSA RADIUS AAA Works, but no EXEC mode
Jan 4th, 2008
  • Bronze, 100 points or more
I have set up my RSA RADIUS server to authenticate logins to my Cisco device(s). And, I have managed to limit which users can login (by assigning them to a Group in RSA and then Activating that group on the router Agent Host). Works fine.
The last thing I'd like to get is for the authenticated user to go directly to EXEC mode (enabled). Right now the user has to do "en" and enter the enable password/secret.
Anybody know how to do this? Thanx in advance.
Paul
Overall Rating: 5 (2 ratings)
cisco24x7 Fri, 01/04/2008 - 12:10
  • Silver, 250 points or more
line vty 0 4
privilege level 15
Here is an example:
[[email protected] root]# telnet 192.168.0.5
Trying 192.168.0.5...
Connected to 192.168.0.5 (192.168.0.5).
Escape character is '^]'.
C
User Access Verification
Username: test3
Password:
Enter your new PIN, containing 4 to 8 digits,
or
to cancel the New PIN procedure:
Please re-enter new PIN:
Wait for the code on your card to change, then log in with the new PIN
Enter PASSCODE:
C2960#
CCIE Security
PAUL TRIVINO Fri, 01/04/2008 - 12:14
Just adding the "privilege level 15" to the line? OK, I'll give it a go. Thanx! (I'll rate if it works...;^)
Paul
PAUL TRIVINO Fri, 01/04/2008 - 14:36
Works like a champ, thanx. I rated the post but I can't figure out how to mark the answer/thread as "this solved my problem." Any idea how?
Thanx again.
Paul
