Cisco 2960 problem
Jan 4th, 2008
I've got these 2960s and I'm trying to upgrade the code, I copy tftp the image but when I try to set the boot statement I get the following error and as a result switch never boots with the new image:
Switch(config)#boot system flash:c2960-lanbasek9-mz.122-40.SE.bin
vb:: Read-only file system
My confi-register is set to 0xF and looks like you can't set the config-register value from the config mode.
johgill Sat, 01/05/2008 - 12:19
  • Bronze, 100 points or more
Try this:
You need to boot to rommon by holding the mode button on the switch while power cycling it.
Run these commands:
flash_init
set_bs vb: rw
boot
After you have booted, add the appropriate variables and you should be all set.
wr mem and reload to test, it should boot fine
