3700 router with NME16es-1G-p module
tcherry
I am having a heck of a time configuring this module and being able to access it and see the port status. I have been on Cisco's website and just having a hard time getting to the right documentation. The router is version 12.4(18) ip base. I have not been able to seeion into the module. When I do a sh inventory it is displayed in the inventory.
NAME: "3745 chassis", DESCR: "3745 chassis"
PID: , VID: 2.0, SN: JMX
NAME: "c3745 Motherboard with Fast Ethernet", DESCR: "c3745 Motherboard with Fas
t Ethernet"
PID: C3745-2FE , VID: 2.0, SN: JAE
NAME: "WAN Interface Card - Serial 2T", DESCR: "WAN Interface Card - Serial 2T"
PID: WIC-2T= , VID: 1.0, SN: 286
NAME: "Wan Interface Card BRI U (2091)", DESCR: "Wan Interface Card BRI U (2091)
PID: WIC-1B-U= , VID: 4.0, SN: 27
NAME: "NME-16ES-1G-P: EtherSwitch SM 16 10/100T PoE + 1 GE", DESCR: "NME-16ES-1G
PID: NME-16ES-1G-P , VID: V01 , SN: FOC
7 Replies 7
Jon Marshall
Have a look at this document which should help you setup the initial config to gain access to the module.
Basically after the module is installed you see a new unused gigabit interface. In short you need to
1) Give the new interface an IP address and issue a "no shut"
2) After this issue the command "service-module gi"slot/int" session
This will then connect you to the module and you can configure it from there.
http://www.cisco.com/en/US/products/hw/modules/ps2797/products_configuration_example09186a0080810449.shtml
Jon
I keep getting the message:
% Connection timed out; remote host not responding
I did a no shut and assigned an IP address with no problem.
What do you get from the output of
service-module gi1/0 status (where gi1/0 is the gigabit connection to the module).
From my 2800 router
Router#service-module gi1/0 status
Service Module is Cisco GigabitEthernet1/0
Service Module supports session via TTY line 66
Service Module is in Steady state
Service Module reset on error is disabled
Getting status from the Service Module, please wait..
EtherSwitch Service Module with 16 FE ports and 1 GE port
System name = 2800-esw
Model string = NME-16ES-1G
System board ID = 0x4018
Base MAC addr = 0017.5978.6200
Switch number = 1
System uptime = 29 days, 13 hours, 32 minutes, 37 seconds
Software Details:
Operating System = Cisco C3750 IOS Software
Vesrion = 12.2(25)SEC2
Major version = 1
Minor Vesrion = 12
Image path = flash:c3750-ipbase-mz.122-25.SEC2/c3750-ipbase-mz.122-25.SEC2.bin
Router#
Atlanta#service-module gigabitEthernet 1/0 status
Service Module supports session via TTY line 33
EtherSwitch Service Module with 16 PoE FE ports and 1 GE port
System name = Switch
Model string = NME-16ES-1G-P
System board ID = 0x18
Base MAC addr = 0018.182b.5700
Switch number = 1
System uptime = 0 days, 0 hours, 1 minute, 34 seconds
Software Details:
Major version = 1
Minor Vesrion = 12
Image path = flash:c3750-ipbasek9-mz.122-25.SEC/c3750-ipbasek9-mz.122-25
.SEC.bin
Looks fine to me from the status. You could try a reset on the module
service-module g1/0 reset
When you try and connect with "service-module gi1/0 sess" what do you see ?
I get
Router#service-module gi1/0 session
Trying 10.5.5.1, 2066 ... Open
2800-esw>
I do have to hit return to get the 2800-esw> prompt.
Jon
I tried moving it to another open slot but I still get a connection timed out message. status still looks good.
Atlanta#service-module gigabitEthernet 3/0 status
Service Module is Cisco GigabitEthernet3/0
Service Module supports session via TTY line 97
Switch number = 1
System uptime = 0 days, 0 hours, 3 minutes, 35 seconds
Software Details:
Major version = 1
Minor Vesrion = 12
.SEC.bin
Can't see too much wrong with this.
if you do a "sh line" from router prompt presumably vty97 is free. You could try clearing the line just to be on the safe side.
I'm running c2800nm-ipbase-mz.124-3c.bin on my 2800.
Jon
