Cisco PIX 515e basic configuration
Answered Question
Jan 4th, 2008
Was wondering if anyone might know why I cant establish basic connectivity from LAN to WAN interface on this machine? I've been trying very hard to get it and I guess its beyond me, very frustrating. Here is a post of the configuration:
Result of PIX command: "show config"
: Saved
: Written by admin at 09:58:27.057 UTC Fri Jan 4 2008
PIX Version 6.2(1)
nameif ethernet0 t1 security0
nameif ethernet1 inside security100
nameif ethernet2 intf2 security10
enable password xxxxx
encrypted
passwd xxxxxxx encrypted
hostname xxxxxxxx
domain-name xxxxxxxx
fixup protocol ftp 21
fixup protocol http 80
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol ils 389
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol sip 5060
fixup protocol skinny 2000
names
pager lines 24
logging trap informational
interface ethernet0 auto
interface ethernet1 auto
interface ethernet2 auto shutdown
icmp permit any echo-reply t1
icmp permit any echo t1
icmp permit any echo-reply inside
icmp permit any echo inside
mtu t1 1500
mtu inside 1500
mtu intf2 1500
ip address t1 x.x.x.124 255.255.255.248
ip address inside 172.20.206.254 255.255.255.0
ip address intf2 127.0.0.1 255.255.255.255
ip audit info action alarm
ip audit attack action alarm
pdm location 0.0.0.0 255.255.255.248 inside
pdm location 172.20.206.254 255.255.255.255 inside
pdm location x.x.x.124 255.255.255.255 t1
pdm location 172.20.206.0 255.255.255.248 inside
pdm history enable
arp timeout 14400
global (t1) 4 x.x.x.125-x.x.x.127 netmask 255.255.255.248
global (t1) 1 interface
global (t1) 2 x.x.x.124
global (t1) 3 x.x.x.122
nat (inside) 1 0.0.0.0 0.0.0.0 0 0
route t1 x.x.x.124 255.255.255.255 x.x.x.121 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h323 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server RADIUS protocol radius
aaa-server LOCAL protocol local
aaa authentication ssh console LOCAL
http server enable
http 172.20.206.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
floodguard enable
sysopt connection permit-ipsec
no sysopt route dnat
telnet 172.20.206.0 255.255.255.0 inside
telnet timeout 5
ssh timeout 5
vpdn enable inside
username xxxxx password xxxxxxxx encrypted privilege 2
username xxxxxx password xxxxxxxxxxxprivilege 2
terminal width 80
Cryptochecksum:xxxxxxxxxx
It would be a relief if my company didn't have to scrap our nice Cisco stuff because we just cant figure it out. Any help would be appreciated!!! Thanks
Correct Answer by adam.sellhorn about 9 years 3 months ago
First off, I would get rid of the unused global PAT entries:
no global (t1) 4 x.x.x.125-x.x.x.127 netmask 255.255.255.248
no global (t1) 2 x.x.x.124
no global (t1) 3 x.x.x.122
Then your route statement seems to be wrong:
no route t1 x.x.x.124 255.255.255.255 x.x.x.121 1
Use:
route t1 0.0.0.0 0.0.0.0 x.x.x.121
Overall Rating: 5 (1 ratings)
Correct Answer
adam.sellhorn Fri, 01/04/2008 - 14:55
Use:
attrib7575 Mon, 01/07/2008 - 09:09
Wow that worked!! thank you so much! I think I was getting caught up in trying to change the interface IP addressees too much. Possibly that's where the incorrect global NAT's were accumulating. I was confused on what IP address to assign the WAN interface. Apparently you give it one of your static addresses, its not the same address as your wan gateway (in this case, the csu/dsu to the t1). Also, the global route is a confusing syntax. I'll have to look at that more. Whatever I typed in seems to work now. Thanks again!!!!
tkuzma1022 Mon, 01/07/2008 - 13:28
try changing your route t1 x.x.x.124 255.255.255.255 x.x.x.121 1 to
route t1 0.0.0.0 0.0.0.0 x.x.x.121 1
To me it appears you are only trying to route x.x.x.124 to the outside (t1) interface.
attrib7575 Tue, 01/08/2008 - 09:56
That may be possible. But, since this configuration works and I've spent so long trying to figure it out. I'm not going to change a thing if I dont absolutely have to. Does anyone know how to permit an incoming Microsoft PPTP client? I have set access rules to permit PPTP and GRE, as well as static NAT to the VPN server on the LAN. IT isnt working, however. I can VPN the server from inside the LAN, so I know that its set up correctly. Its something to do with the firewall.
mark.j.hodge Wed, 01/09/2008 - 08:53
  • Bronze, 100 points or more
You need to setup a static mapping from an unused IP address from your CIDR range, to your VPN server. Then allow the appropriate traffic inbound to the mapped address on your t1 interface.
** please rate posts if helpfull **
attrib7575 Wed, 01/09/2008 - 11:42
Yeah, thanks. As I mentioned above, the connection works, as well as RDP now. I have taken up the VPN in another topic. THanks everyone!
