AvCsNodeMgr not hearing from partner server
Erick Bergquist
Level 6
Level 6
Anyone know what is going on here?
This is a Unity 4.0(5) server and both unity servers are connected to the same 3750 switch. No errors on switch ports or in the switch logs, everything looks clean.
Sometimes this error is seen on both servers about each other losing connection to the other, but most of the time it is only seen on the primary server then it recovers on it's own.
The servers NIC is set to auto, as well as switch port, running at 1 gig full duplex.
Event Type: Error
Event Source: CiscoUnity_NodeMgr
Event Category: Run
Event ID: 1011
Date: 1/4/2008
Time: 10:12:38 PM
User: N/A
Computer: UNITY1
Description:
AvCsNodeMgr hasn't heard from partner UNITY2 in 57021 ms, disconnecting.
For more information, click: http://www.CiscoUnitySupport.com/find.php
Event Type: Information
Event Category: Init
Event ID: 1021
Date: 1/4/2008
Time: 10:12:39 PM
User: N/A
Computer: UNITY1
Description:
AvCsNodeMgr connected to server UNITY2, address=172.16.1.20, port=3653.
Ginger Dillon
Hi -
Take a look at this Cisco link to see if it applies - http://www.ciscotaccc.com/kaidara-advisor/voice/showcase?case=K11922450 - even though it refers to Unity version 4.2(1).
Ginger
Thanks Ginger, but it doesn't have SATA drives or drivers. I do remember that issue though...
Looks to be a intermittent network issue at this point.
