chschroe Sat, 01/05/2008 - 02:10
That's right, its just the one in the 3745.
That gives you basically 184 ISDN B channels or DS0s, which is quite a bit for that router.
NS
ahmedssk Sat, 01/05/2008 - 02:38
Many Thanks, one question is it better to go for the NM-8CE1T1-PRI with 128 channels or 4x of NM-2CE1T1-PRI with 128 each?
paolo bevilacqua Sat, 01/05/2008 - 04:48
  • Hall of Fame,
    Founding Member
Note, the NM-8CE1T1-PRI is supported only on the 3800 series router, and not on the 3700. So you will have to use the other solution for the 3700.
