The switch ships with a default VLAN to which all the switch ports initially belong. The switch supports a maximum of 32 VLANs, including the default VLAN. Using only the default VLAN might be sufficient based on the size and requirements of your network. We recommend that you first determine your VLAN needs before you create VLANs.
Cisco Catalyst 500 series switches work in VTP Transparent mode. VLAN creation, modification, or deletion done on this switch does not affect the other switches in the domain.
