Warning message
Outgoing Mail can't be send
Jan 5th, 2008
Hi all!
I use a ASA 5505 in standard config. Today I noticed that I can't send emails with attachments bigger then 100kb anymore since I changed my firewall to the ASA.
I'm using MACOSX 10.5.1 with Mail 3.0. When trying to send mail without attachments it works nicely, but with attachments it will stop at some stage (e.g. 23%) as if the connection was lost and then Mail times out.
When using a different firewall I don't have any problems.
Funny thing is, when using a Win machine and thunderbird I don't have any problems at all, even with attachments.
Any ideas on how to solve the Problem? Does anyone have similar problems?
Thank you very mch for any help
Sebastian Esch
seehundnz Fri, 01/11/2008 - 10:36
hi !
thanks but I updated to version 8 and the problem is gone.
thanks anyway
