pager line problem !!!
Jan 5th, 2008
I have Two pix firewall and os 7.1(2)
one is core and other is normal operation.
In core FW huge connection eastablish. problem is when I execute sh run then last line come. For remove this I give comand pager line 10. when I excute this command then configuration come in 10 lines. after some period 12 hours or 24 hours its goes previous condition.
In another FW work is fine. so how I get rid of from like this problem.
Biplob
iqbalkhan Mon, 01/07/2008 - 03:19
I can access Telnet and SSH. But problem is same.
thanks
Biplob
Satya Siba Sund... Thu, 09/25/2008 - 13:28
i am facing the same problem but i am using pix 515E running 6.3(5).did your problem get resolved, if yes what option you have tried??
