01-05-2008 10:35 PM - edited 03-13-2019 04:51 PM
hello,
I want to know if there are any issues on using IP communicator from remote thru a VPN which is terminated on an ASA 5500.
If there are issues, recommendations are welcome.
Thanks.
01-06-2008 10:05 AM
other than QoS on the Internet no you will be just fine.
01-16-2008 01:00 PM
Extension Mobility doesn't work with IP Communicator through VPN but it is not necessarily a problem with the concentrator. It is the same MAC addresses for all VPN clients confusing Extension Mobility.
01-23-2008 07:34 AM
There can be, yes.
If you use AES encryption on your VPN, you'll need to make sure you don't use VPN client 4.6 thru 4.8.
Here's a link: http://www.cisco.com/cgi-bin/Support/Bugtool/onebug.pl?bugid=CSCsd69887
