PBX with Router: Multiple trunks
Jan 6th, 2008
Friends,
I am currently working on voip setup. I connected a router with a pbx through a Pri (qsig). I configure dial-peers both for voip and pots. so when a call come to router, it matches the pots dial-peer and forward call to pbx on specific port that i mention in dial-peer.
Now my question is if have 3 trunk with the same pbx. One way is that i configure 3 pots dial-peer with same destination and define all 3 ports in them. like
dial-peer voice 10 pots
destination-pattern 3...
port 1/0
dial-peer voice 20 pots
port 1/1
dial-peer voice 30 pots
port 2/0
but i believe this is not the way. Please tell me the actual way to assign multiple ports for a dial-peer.
Best Regards
Paolo Bevilacqua Sun, 01/06/2008 - 04:12
The proper way, it's trunk groups:
voice-port 1/0
trunk-group pbx <-- repeat for all voice-ports
dial-peer voice 3 pots
trunkgroup pbx
Then under "trunk group pbx" you can configure additional options like translation-rule, hunt schemes, etc.
rameezsardar Sun, 01/06/2008 - 13:34
Thanks Friend,
Yes you r right, i need to configure trunk-group but not under voiceport but under e1 pri d-channel.
NOCSOC SSP Sun, 07/13/2008 - 00:00
Hi, i have the same situation, I duplicate the dial peers adding the preference command.
preference 0
port serial 0/1/0:1
preference 1
port serial 0/0/1:1
mmmm but i supose that this solution is not the best, then again, please tell me the best way to assign multiple ports for a single dial-peer.
Paolo Bevilacqua Sun, 07/13/2008 - 02:45
Trunk-group under voice-port. The reference it in the DP (do "no port" first).
Please rate post if it helps!
