Interface Configuration
rmwhite59
Why is the being shown on eth0/0 and eth0/1 ?
Traffic Statistics for "inside":
12012747 packets input, 1762314015 bytes
15294460 packets output, 15323589877 bytes
317420 packets dropped
1 minute input rate 2 pkts/sec, 196 bytes/sec
1 minute output rate 1 pkts/sec, 388 bytes/sec
1 minute drop rate, 0 pkts/sec
5 minute input rate 1 pkts/sec, 219 bytes/sec
5 minute output rate 1 pkts/sec, 362 bytes/sec
5 minute drop rate, 0 pkts/sec
Interface Vlan2 "outside", is up, line protocol is up
Hardware is EtherSVI, BW 100 Mbps, DLY 100 usec
MAC address 001d.a2f4.d372, MTU 1500
IP address xx.xx.x.136, subnet mask 255.255.255.128
Traffic Statistics for "outside":
14662243 packets input, 15342849094 bytes
10872119 packets output, 1595307364 bytes
103835 packets dropped
1 minute input rate 1 pkts/sec, 435 bytes/sec
1 minute output rate 2 pkts/sec, 239 bytes/sec
5 minute input rate 1 pkts/sec, 356 bytes/sec
5 minute output rate 1 pkts/sec, 203 bytes/sec
Interface Ethernet0/0 "", is up, line protocol is up
Hardware is 88E6095, BW 100 Mbps, DLY 100 usec
Full-Duplex(Full-duplex), 100 Mbps(100 Mbps)
Available but not configured via nameif
MAC address 001d.a2f4.d36a, MTU not set
IP address unassigned
14662259 packets input, 15615045391 bytes, 0 no buffer
Received 1539 broadcasts, 0 runts, 0 giants
301 input errors, 301 CRC, 0 frame, 0 overrun, 301 ignored, 0 abort
0 L2 decode drops
0 switch ingress policy drops
10872138 packets output, 1835905059 bytes, 0 underruns
0 babbles, 0 late collisions, 0 deferred
0 lost carrier, 0 no carrier
0 rate limit drops
0 switch egress policy drops
Interface Ethernet0/1 "", is up, line protocol is up
MAC address 001d.a2f4.d36b, MTU not set
12023333 packets input, 2030829022 bytes, 0 no buffer
Received 501322 broadcasts, 0 runts, 0 giants
8737 input errors, 8737 CRC, 0 frame, 0 overrun, 8737 ignored, 0 abort
0 L2 decode drops
15294460 packets output, 15613441291 bytes, 0 underruns
0 rate limit drops
JORGE RODRIGUEZ
Level 10
Level 10
your interface errors is typical indications of speed/duplex missmatches, even though you have 100/full duplex hard coded on interface inside and outside check that whatever they connect to the speed and duplex is also hardcoded..
if your inside physical is connected to a switch make sure switch port is set to 100/full, same for outside, in some cases outside connects to unmanageable device where you cannot set the transmission speed, if this is the case then make your outside firewall physical interface is set to auto/auto.
after you check these and make proper speed corrections issue clear counters on firewall and look at the interfaces to see if problem is gone.
Rgds
Jorge
Jorge Rodriguez
