VPN Client issue
Jan 6th, 2008
I've configured our router to allow vpn client(IPSec Type , not pptp) to access our network , with cisco vpn client , connection is made successfully and authenticates but I've got two problems with it :
1)when the client authenticates in it can't see anywhere , although I've created an access list allowing them(VPN Range) to access any.
2)with IP local pool I can't assign any gateway to the users , how is it possible to assign a gateway for the remote VPN clients.
here is the main part of my config:
crypto isakmp policy 1
encr 3des
authentication pre-share
group 2
crypto isakmp key xxxxx address 0.0.0.0 0.0.0.0
no crypto isakmp ccm
crypto isakmp client configuration group xxxx
key xxxxx
dns x.x.x.x
domain x.com.au
pool xpool
netmask 255.255.255.0
crypto isakmp profile VPNclient
description VPN clients profile
match identity group xnet
client authentication list clientauth
isakmp authorization list groupauthor
client configuration address respond
crypto ipsec transform-set x-set esp-3des esp-sha-hmac
crypto dynamic-map dyna-x 1
set transform-set x-set
set isakmp-profile VPNclient
crypto map xMap 5 ipsec-isakmp dynamic dyna-x
ip access-list extended VPN-Client
permit ip any 172.31.120.0 0.0.0.255
ajagadee Wed, 01/09/2008 - 19:31
  • Cisco Employee,
Do you have any NAT configured on the router. If so, have you bypassed NAT range of IP Addresses configured for the Pool xpool.
Once the VPN Client is connected, can you capture the "Show crypto ipsec sa" and post the outputs.
Arul
