two subnets on inside interfac of PIX
Answered Question
Jan 6th, 2008
I have a PIX with two interfaces, outside and inside. I would like to add a second IP subnet to the inside interface. With routers I would use the "secondary" keyword in the "ip address" command. I don't seem to see anything similar with the PIX. Will I be able to do this?
Diego
Correct Answer by JORGE RODRIGUEZ about 9 years 2 weeks ago
Hi Diego, as said by previous posters, but to be more specific you need minimun version of 6.3(5) to support logical interfaces. For you to be able to split you inside physical into logical segments you will need to use 802.1q trunking to accomplish this. I would like give you a startup example and requirements if you decide implementing this.
Here is a basic script and basic steps.
What is needed : Switch capable of of doing dot1q trunking, for pix side as soon as you assign keyword on the interface 802.1q is automatically turned on without any other commnads as there is none for turning on trunking and your VLAN defined in FW.
1- Allocate port on switch to create trunking
between switch and and PIX515E, say you pick Fe0/48 on a 3550 switch.
Define and create VLANs in switch. Say VLAN2 for firewall , VLAN3 for firewall .
2- Allocate a physical interface in PIX to connect to switch port Fe0/48., on PIX say you allocated inside interface ethernet1.
3- Define your security levels, if you are running code 6.3(5) cannot have same security level on interfaces and if you want to not have to deal with NATing between the two you could create a No_NAT acl and apply if to the interfaces, as for security you could use 100 for inside and 99 for inside2 interfaces. If you are running code version 7.x or above you have the option to use same secutity level on interfaces and use command to avoid acls.
example using 10.2.2.0/24 as VLAN2 and 10.3.3.0/24 as VLAN3 for trusted LAN.
If using 6.3(5)
interface ethernet1 100
interface ethernet1 vlan2 physical
interface ethernet1 vlan3 logical
nameif ethernet1 inside security100
nameif vlan3 inside2 security99
ip address inside 10.2.2.1 255.255.255.0
ip address inside2 10.3.3.1 255.255.255.0
global(outside) 1 interface
nat(vlan2) 1 10.2.2.0 255.255.255.0
nat(vlan3) 1 10.3.3.0 255.255.255.0
Switch_3550:
vlan database
vtp transparent
vtp domain test
vtp password cisco
vlan 2 name FW_Inside_10.2.2.0/24
vlan 3 name FW_inside2_10.3.3.0/24
Interface fastethernet0/48
Description trunk_Connection_PIX_Ethernet1
speed 100
duplex full
switchport mode trunk
switchport trunk allowed vlan 2,3
no shutdown
If using PIX 7.x code and above
interface ethernet1
speed 100
duplex full
nameif Inside_LAN
security-level 100
no ip address
interface Ethernet1/1.1
vlan 2
nameif vlan2
security-level 100
ip address 10.2.2.1 255.255.255.0
interface Ethernet1/1.2
vlan 3
nameif vlan3
security-level 100
ip address 10.3.3.1 255.255.255.0
same-security-traffic permit inter-interface
for switch part same principle as 6.3(5) example.
Rgds
Jorge
Overall Rating: 5 (3 ratings)
Fernando_Meza Sun, 01/06/2008 - 19:46
Hi ..
I am suspecting you have a PIX 501 model which does not support VLAN interfaces in which case you can't use the internal interface for creating two segments.
I hope it helps .. please rate it if it does !!!
DIEGO ALONSO Sun, 01/06/2008 - 22:15
I am actually working with a 515E and I don't see any VLAN related commands. However, I hadn't thought about VLANs as a possibility so I will investigate that.
Diego
Correct Answer
JORGE RODRIGUEZ Mon, 01/07/2008 - 10:37
If using 6.3(5)
Switch_3550:
vlan database
vtp transparent
vtp domain test
vtp password cisco
speed 100
duplex full
no shutdown
interface ethernet1
speed 100
duplex full
nameif Inside_LAN
security-level 100
no ip address
vlan 2
nameif vlan2
security-level 100
vlan 3
nameif vlan3
security-level 100
Rgds
Jorge
