URL filtering for PIX or ASA
Jan 6th, 2008
Other than WebSense, what options are out there? Is N2H2 the same as SecureComputing SmartFilter? SmartFilter says that it supports PIX via IFP but the web site isn't clear on what IFP is.
Diego
Fernando_Meza Sun, 01/06/2008 - 20:13
  • Gold, 750 points or more
Hi ..
Smartfiletr is the same product .. it was formerly known as N2H2 .. IFP stands for Internet Filtering protocol which is used for communication between the ASA and the Filtering server
http://cisco.com/en/US/products/hw/vpndevc/ps2030/products_configuration_example09186a008088517b.shtml
I hope it helps .. please rate it if it does !!!
