Out of the box in the device theres no method to determine that, the only statistic you could use is chassis uptime.
First you need to determine what your minimum acceptable criteria for being "up" are. Is a simple layer 2 link sufficient ? Or do you need to track the availablity of a specific interface dependant facility like a MPLS VPN ? Both can be specified as up with a very wide gap in criteria.
