CUCMBE 6.0 on VMWARE
Jan 7th, 2008
Has anybody sucessfully installed CUCMBE on VMWARE in a lab? I am having problem installing CUCMBE in lab environment. It seems to be happy to install the CUCM but fails to install Unity Connection and bombs out giving an unknown error. The machine I am using has got 2 GB physical memory and the VMWARE machine has been configured with 528 MB memory and 50 GB HDD. Any help will be much appreciated.
Cheers
Ati
HYE WILSON Tue, 01/08/2008 - 14:13
I had the same problem installing CUCMBE on VMWARE. The exact same problem you described. I would love to know if anyone was able to do this.
TIA,
HYW.
yogesh.mhatre Thu, 02/05/2009 - 12:37
You can give a try with hard drive size 146GB and do not allocate the drive space.
Hope this helps.
Jonathan Schulenberg Thu, 02/05/2009 - 16:34
  • Cisco Designated VIP,
    2017 IP Telephony
This works with CUCMBE 7.0(1) at least. I have it running in my lab.
It is worth noting that this normally runs on 6GB of RAM in a MCS7828 server. I really doubt it is going to work with such a low amount. Tomcat will crash for sure. Give it a lot more ram and at LEAST 72GB of drive space and see what happens.
mikram Mon, 02/09/2009 - 03:37
  • Bronze, 100 points or more
You need 2Gig of Ram for CUCM and 2 Gig of Ram for UC. So, if you have 2 gigs only, what you could do is that first install CUCM with 2gigs of RAM and after installation, lower the RAM setting to 700 MB on vm image for CUCM, Install UC with 2gigs of RAM and after installation you could use also around 800Mb of ram for UC. Bit slow, but does the job. Make sure you have 80 gigs of Hard disk space for each vm image. Try to split it into 2gigs files.
Cheers
Ikram
bigcappa1 Wed, 02/18/2009 - 00:13
  • Silver, 250 points or more
I had the same issue with all version 6 CUCMBE I ended up just installing CUCM on one VMWARE session and Unity on another. It still works like allowing you to import users etc just measn you cant manage the administration of both applications through the same browser window
Paul
jaipal Wed, 02/18/2009 - 03:03
Hello friends,
You can install the CCM6.x on the VMware succesfully.
Install the Ubuntu on the PC with 2 GB RAM, install VMware server and while creating the VM Machine choose the OS are RedHat server 3 entprise. Hard disk must be 72 GB, memory alloation 1 GB. Split files to 2 Gb each. After this you may install CCM6.
Justin Brenton Wed, 02/18/2009 - 15:19
I'm running CUCMBE 6 with Unity, IPCC, AD, Presence on a pc with 3g duo core, 8 gb of ram, 1 terrabyte hd....Using Linux as the VM Host... Runs very smooth...
I would suggest Linux for VMware as the OS takes much less overhead and you can track your memory usage much easier.
Justin
