Problem with incoming calls
jklopottek
i need a solution for the following problem: Incoming calls are functinally after a second try. The caller hears at first try the message" The number is not assign". The System is a CCME 4.2 on a Cisco2811 with IOS version 12.4(11)XW2
What can i do to resolve this problem?
Jörg
MARTIN STREULE
Hi Jörg,
"After 2nd try" and "incoming" sounds like you have 2 PSTN interfaces with different translations or COR stuff on them.
Check your interfaces for differences in the config and check if you get the same numbers (length) from the provider.
/Martin
