AS5300 stuck in ROM mode
Jan 7th, 2008
I am using Cisco AS5300 with IOS 'c5300-is-mz.123-6.bin'. Whenever the AS reboots (abnormally, e.g. power recycle), it stuck in ROM mode. Then there is a need to hard reset the AS, OR reset the AS through console.
Is there any other way? upgrading IOS? etc.
Thanks in advance
PAUL TRIVINO Mon, 01/07/2008 - 12:52
  • Bronze, 100 points or more
I haven't used an AS5300 in a while, but this *sounds* like a configuration register problem. Don't remember the setting but the config reg is a bitmap, the bit that says "boot to IOS" must be OFF. Someone here should know...
Paul
Farhan Jaffer Tue, 01/08/2008 - 06:17
This is not config register issue. It's 0x2102 (boot from IOS)
Any other ideas?
KAROLY KOHEGYI Wed, 03/04/2009 - 04:50
I have same experience with as53500.
Have you find any solution for this problem.
Thank in advance,
