C3750 problem booting up
Jan 7th, 2008
Hi everyone
I just got a new catalyst 3750 and having some boot problems already..
I insert the power and it doesnt really start up (fans)
All the Led lights blink together and then go out, then blink and go out continiously.
Tried to consol it but nothing happens.. Seems like it cant do the POST at all?
Is there anyway I can save it? Or should I just toss it and get a replacement?
Overall Rating: 5 (1 ratings)
ankbhasi Mon, 01/07/2008 - 06:02
Hi Friend,
If the fan does not even start then it could be faulty hardware. But I will recommend you to try changing the baud rate on your console connection and also try different console cable and if still nothing comes on console it calls for hardware replacement.
Ankur
*Pls rate all helpfull post
